Please sign up for a premium account to access the coaching page.
Progress Monitoring on P-3
  • Posted on 03/01/21 - 5:56 p.m.
Is there a certain words per minute that students should read before moving on to the next skill (CVC to Digraphs to ...)?  I know that they need 90% accuracy. I saw in the binder that 19 correct and 1 error (95% accuracy) and moved to the next level.  I also saw 18 correct and 2 errors and (90%) and moved to the next level.  So, could they get 9 correct and 1 error (90%) and still pass the level?  I appreciate your feedback.
Thank you,
Alicia
  • Posted on 02/24/22 - 7:50 p.m.
When I went through the training, they said the 3 second rule applied. So technically they should get to 20 words in 1 minute at least to pass, if not, you continue because they need to build fluency on the skill. Then they can can get 2 wrong because that gets them 90%.
So when doing skill monitoring the first question is, did they get at least 20 words? The second question is, did they have 90% accuracy. If not continue with the skill.
