Path to Reading Excellencein School Sites
We are using the PRESS skill monitoring and would appreciate some guidance.
1. Are the word lists timed for one minute?
Each list has a spot for sounds read/minute and words read/minute.
2. Is there a minimum of words students should be reading at 90% accuracy IF the passages are timed for one minute?
3. If the passages aren't timed, what is a reasonable amount of time to allow to read the list?
All lists appear to have 50 words.
Thanks.
Thanks.
